18 years agoMemory map cannot fit?
I have written my own interface to a SDRAM and trying to add it i SOPC builder as an avalon tristate slave. The component is created without any error messages, but when adding it to my SOPC system I...
18 years ago --- Quote Start --- I have written my own interface to a SDRAM and trying to add it i SOPC builder as an avalon tristate slave. The component is created without any error messages, but when adding it to my SOPC system I get, But both the address bus and the data bus widths are only 32 bits wide, so what can the problem be? cheers! --- Quote End --- 1. Try "System Menu -> Auto-Assign Base Addresses". 2. Also what is your sequence of adding the components? You should add your SDRAM after adding the cpu. flash, cpu_ram etc.
