16 years agoMegawizard DDR signal primitive issue
Hopefully this is an easy one, but I have been hitting my head now for 2 days. This seems to be a low level primitive issue. These are my errors: Error: Output port "OBAR" of PSEUDO_DIFF_OUT ...
14 years agoInfo for those searching (in case anyone still is): I ran into this error when trying to port SIII ddr2 from 9.0 altmemphy up to 11.1 Qsys uniphy:
Error (15853): Input port IBAR of I/O input buffer "stratixIII_3sl150_dev_niosII_standard_sopc:this_stratixIII_3sl150_dev_niosII_standard_sopc| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0:p0| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0_memphy:umemphy| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0_new_io_pads:uio_pads| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs| altdq_dqs2_ddio_3reg_stratixiii:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15852): Output port "OBAR" of PSEUDO_DIFF_OUT primitive "stratixIII_3sl150_dev_niosII_standard_sopc:this_stratixIII_3sl150_dev_niosII_standard_sopc| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0:p0| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0_memphy:umemphy| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0_new_io_pads:uio_pads| stratixIII_3sl150_dev_niosII_standard_sopc_mem_if_ddr2_emif_0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs| altdq_dqs2_ddio_3reg_stratixiii:altdq_dqs2_inst|pseudo_diffa_0" must drive only one OBUF primitive on the I port and cannot drive anything else It appears that Quartus II still generates has the original 9.0 assignment groups including ddr2_deva_dqs_n but now requires the _n side declaration “inout ddr2_deva_dqs_n” on the top level file stratixIII_3sl150_dev_niosII_standard.v as well: Adding this declaration to the top level stratixIII_3sl150_dev_niosII_standard.v resolves the error: inout ddr2_deva_dqs_p, inout ddr2_deva_dqs_n, The UniPhy also requires OCT RUP/RDN for each device which also need to be assigned. I ported for just ddr2_deva (device a) for now (pls check stratixIII_3sl150 dev kit web page for 11.1 installer update: standard design) but I assume making another UniPHY for device b will require the same adaptations (i hope). If I get bothe ddra & ddrb working together, I will update this thread.
