16 years agomeasuring power consumption
Hi, I created a custom block and integrated it into the my system using SOPC Builder. I need to measure the power consumption of my custom block (instead of the whole system), but I am not...
16 years agoWhat I have done before is make that block my top level entity and run the power play estimator. This kind of gives a general idea. When your design is complete, those numbers may or may not be accurate depending on how Quartus rearranges/optimizes your design - the difference can be so that the numbers generate for that block alone are not meaningful. The suggestion from Daixiwen would yield a more accurate result.
