10 years agoMeasuring clock from DE0-Nano on scope
Hi, I have a clock divider in my design, that takes the 50MHz clock in the DE0-Nano board and divides it so that I get 1MHz in it's output (I can't use a PLL since 50M to 1M is impossible). ...
10 years agoThanks for the reply and sorry for my late one.
Like I said, a few weeks ago it worked. A few hours after writing this post, it started working again, so I forgot about this thread. To answer your questions: 1. According to the Quartus pin planner, it is LV-TTL 3.3V 2. Yes, a reset signal zeroes the clock signal. It is the only signal that has any effect. 3. Now, Yes. Before I did not. I should mention I do not see a clear square wave but I assume that's because 50MHz is too high for the scope. 4. It is working. One important thing I should mention - the clock signal from my clock divider I'm seeing now has a low maximum voltage. The DE2 pins, as far as I know, should have an output of 5V (like the VCC) or at least 3.3V. Problem is that the clock signal has a maximum voltage of 1.5V barely. Any known issue that can cause this? Also, the same clock signal that is the output of the divider is used to clock many modules. I heard that in the assignment editor you can tell the Quartus program that this is the case by assigning it as a global clock or something like that. Is it true, and if it is, what is the correct assignment? Thanks!
