17 years agomay i use the global oe pin as the global reset pin?
the device i am working with is EPM570T5I, and and i need two reset pins,but the device just has one global reset pin,so i want to use the global oe pin as the global reset pin, and this works? anoth...
17 years ago --- Quote Start --- Unlike global reset, global OE isn't said to have dedicated routing resources. Thus a GCLK input would be the preferred source to minimize routing effort with your second reset input. I don't expect timing issues with a global reset, normally. If unrelated to the system clock, it should be synchronized for safe reset behaviour anyway (a feature, that can't be achieved with the dedicated global reset input, by the way). --- Quote End --- nice job,thank you very much!
