johnson037
1 year agoMay I Use MIPI Strandard IO (HS/LP Compatible IO) Without Using Altera MIPI-DPHY IP
Hi : From the Altera agilex 5 MIPI D-Phy IP User Guide, We Know that We can use MIPI Standard IO (HS/LP Compatable IO) By Using Altera MIPI DPhy IP. ...
Wincent_Altera
1 year agoHi ,
Please accept my late response.
So agilex 5 FPGA Do actually have MIPI Standard IO (HS/LP Compatable IO), is the answer Correct !?.....
>> following user guide under https://cdrdv2-public.intel.com/834802/ug-817561-834802.pdf
>> There is a block who handles the external incoming data deserialization with its clocking for both HS and LP modes
Wincent
