11 years agoMAXV - User Flash Memory Time Constraints
I try to time constrain my design using Altera block ALTUFM_SPI. I get many warnings from Quartus software like this one: Warning (332009): The launch and latch times for the relationship between source clock: clk_dsp_dpi_p4 and destination clock: inst54|auto_generated|maxii_ufm_block1|osc are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0. I cannot succeed to get rid of those warnings. Would someone have an example (more likely an SDC file example) on how to constrain ALTUFM_SPI? Thank you in advance for your comments. Fabe1 Reply
I have still not been able to meet timing requirements with ALTUFM_SPI Block. I have defined an sdc file with four inputs and one output: Inputs name: SCK - NCS - OSCENA - SI Output name: SO For some reason, I still get unconstrained paths even if it seems that all are constrained. I still get warning messages and error messages like the one below: ------------ Warning (332009): The launch and latch times for the relationship between source clock: osc1 and destination clock: osc5 are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0. ------------ Critical Warning (332148): Timing requirements not met Someone would have some input regarding this? Thanks, Fabe My SDC file is like below: # SDC file create_clock -name "osc1" -period 1000.0ns [get_ports {SCK}] create_clock -name "osc2" -period 1000.0ns [get_ports {NCS}] create_clock -name "osc3" -period 1000.0ns [get_registers {altufm_spi:inst|altufm_spi_m8s:auto_generated|dffe28}] create_clock -name "osc4" -period 1000.0ns [get_registers {altufm_spi:inst|altufm_spi_m8s:auto_generated|dffe31}] create_clock -name "osc5" -period 181.818ns [get_pins {inst|auto_generated|maxii_ufm_block1|osc}] # Automatically constrain PLL and other generated clocks derive_pll_clocks -create_base_clocks # ############################################################################################### # Block CPLD_EEPROM # tsu/th constraints # tco constraints # tpd constraints set_min_delay 10 -to [get_ports {SI}] set_max_delay 80 -to [get_ports {SI}] # set_min_delay 1 -to [get_ports {SCK}] # set_max_delay 8 -to [get_ports {SCK}] # set_min_delay 1 -to [get_ports {NCS}] # set_max_delay 8 -to [get_ports {NCS}] set_min_delay 10 -to [get_ports {OSCENA}] set_max_delay 80 -to [get_ports {OSCENA}] set_min_delay 10 -to [get_ports {SO}] set_max_delay 80 -to [get_ports {SO}]
