10 years agoMAX+plus II 8.0
Ok, first off, I know that version 8.0 of MAX+plus II, from 1997, is old, obsolete, etc. However, I'm desperately trying to recreate a build of some old VHDL code in an attempt to reproduce a binary ...
10 years ago --- Quote Start --- Geez, I sure hope that's not the case... The Altera Configuration File for the build does not specify any sort of random number seed, so I'm assuming/hoping that this version of MAX+plus II doesn't use random numbers. I did the front end synthesis using Synopsys Synplify version 3.0, and it produced identical results to a build from 1997, so it doesn't appear to use random numbers. --- Quote End --- Synth isnt random - its the fit that is random (based on a seed that you can control).
