15 years agoMaxPlus 2: compiling errors
Hello everyone, i am berni69 and I'm studing telematics with our software, but like all the begginers in a new field, i have some mistake's programming in vhdl. For this reason the compiler show me errors that i could solve, all except one.
I want you help me if it's possible. Thanks, now I will paste my code:library ieee;
USE Ieee.Std_Logic_1164.All;
Entity mod_tr IS
Port (Data: IN Std_Logic_Vector(3 Downto 0);Recepcio,Tr,Clk,Start: IN std_logic;
Transmissio: OUT std_logic; Reg_Entrada: OUT Std_Logic_Vector(3 Downto 0));
END Mod_Tr;
Architecture Comportament OF Mod_Tr IS
--signal: s0,s1,clr,qm,qn,qo,qp: bit;
signal clr: std_logic;
signal contador: integer range 0 to 4;
BEGIN
process (start,clk,clr)--contador
variable n: integer range 0 to 4;
begin
n:=contador;
if clk'event and clk='1'then
if start='1' or clr='1' then
n:=0;
elsif contador/=4 then
n:=n+1;
elsif contador=4 then
clr<='1';
end if;
end if;
contador <= n;
end process;
process (clk, clr, data, tr, recepcio)
variable shift: Std_Logic_Vector(3 Downto 0);
begin
if clk'event and clk='1' then
if clr='1' then
shift:=data;
elsif tr='1' then
--transmitim=> desplaçament a la dreta
shift(0):=shift(1);
shift(1):=shift(2);
shift(2):=shift(3);
shift(3):='0';
elsif tr='0' then
--rebem => desplaçara l'esquerral
shift(0):=recepcio;
shift(1):=shift(0);
shift(2):=shift(1);
shift(3):=shift(2);
end if;
end if;
reg_entrada<=shift;
transmissio<= shift(0);
end process;
In the first proccess i get the error: "else clause following a clock edge must hold the state of signal n" The line is: if clk'event and clk='1'then Lot of thanks!2 Replies
Ohh thanks!! with your help i solved my problem!!
The error message isn't fully correct, because there is no else clause to the clock edge condition. Quartus gives a better understandable message.
--- Quote Start --- Error (10818): Can't infer register for "n[0]" at mod_tr.vhd(22) because it does not hold its value outside the clock edge --- Quote End --- The code can be compiled, when you change it like this:
You can write the same logic without the variable n. I don't think, that the code works as expected, because the signal clr is only set but never reset.process (start,clk,clr)--contador variable n: integer range 0 to 4;for the begin if clk'event and clk='1'then n:=contador; if start='1' or clr='1' then n:=0; elsif contador/=4 then n:=n+1; elsif contador=4 then clr<='1'; end if; contador <= n; end if; end process;
