10 years agoMaximum Size of Flash Memory Supported by CycloneIII
Dear Host, Please tell me, how much maximum density of Flash Memory is supported by Cyclone III EP3C120F780I?
10 years ago --- Quote Start --- Thank you sir. This point is clear to me. I want to discuss one more point with you. I want to configure this device with FPGA for general purpose use. When i run the Memory Test, its give the error, "Flash is not open". Please guide me how can i debug this issue. --- Quote End --- Try debug into library code and find out what exactly generates the error. I guess the Altera HAL driver doesn't support that specific device size; if you are lucky it's simply a matter of adding the device code to the list of supported ones.
