10 years agoMaximum avaliable frequency with the altera_gpio at Arria 10
Hello!
I try to create very simple DDR register with help of AlteraGPIO megafunction. This project must generate clock (200 MHz) and periodical data pulse at rising edge of clock, which has 90 degree phase relationship with data (see attachment wave.png). Thats code of my project:
module test_sdc
input bit ref_clk,
output bit clk_out,
output bit data_out
// Generate reset signal for PLL
bit reset_cntr = '0;
bit reset_pll;
always_ff @(posedge ref_clk) begin
if (reset_cntr != '1)
reset_cntr <= reset_cntr + 1'b1;
end
assign reset_pll = reset_cntr != '1;
// Generate clock and reset
bit reset_n, core_clk, out_clk;
pll pll_25_200
.locked ( reset_n ),
.outclk_0 ( core_clk ),
.outclk_1 ( out_clk ),
.refclk ( ref_clk ),
.rst ( reset_pll )
// Generate data signal
bit data_cntr;
always_ff @(posedge core_clk) begin
if (!reset_n)
data_cntr <= '0;
else
data_cntr <= data_cntr + 1'b1;
end
assign data_flag = data_cntr == '1;
// Create DDR output for data and clock
ddr_reg ddr_data
.ck (core_clk),
.din ({1'b0, data_flag}),
.pad_out (data_out)
ddr_reg clk_data
.ck (out_clk),
.din (2'b01),
.pad_out (clk_out)
endmodule
Also I defined constraint for TQ:
create_clock -period 25MHz
derive_pll_clocks
derive_clock_uncertainty
create_generated_clock -name ext_clk_pin -source ]
set_output_delay -clock -max 0.5
set_output_delay -clock -min -0.5
set_output_delay -clock -max 0.5 -clock_fall -add_delay
set_output_delay -clock -min -0.5 -clock_fall -add_delay
set_false_path -setup -fall_from pll_25_200|iopll_0|outclk0 -rise_to ext_clk_pin
set_false_path -setup -rise_from pll_25_200|iopll_0|outclk0 -fall_to ext_clk_pin
set_false_path -hold -fall_from pll_25_200|iopll_0|outclk0 -fall_to ext_clk_pin
set_false_path -hold -rise_from pll_25_200|iopll_0|outclk0 -rise_to ext_clk_pin
set_false_path -from -to
But compilation at Quartus Prime 15.1 was unsuccessful: design has a negative slacks for slow models (see TQ.png for detalies). For test purposes I compile that project for Cyclone 3 device (with change AlteraGPIO to ALTDDIO_OUT) - and it was compilated sucessful! Please, help me to understand why Cyclone 3 are more quickly that Arria 10No RepliesBe the first to reply
