13 years agoMAX7000 Power Supply Problem
I'm using Max7000 cpld. Sometimes MAX7000 doesn't work. No signals out. This happens when it passed some time in state of being off. Other CPLDs and FPGAs work well on same condition. A...
12 years agoCould be any of a number of things. Correct voltage? Enough bypass / Decoupling capacitors? Pins configured correctly? Another thing to keep in mind is that the 7000-series has only a finite number of programming cycles, somewhere around 100 or thereabouts.
-Mux
