17 years agoMAX7000 power and Slew rate control
Hi All, I have having problems with a simple 15 bit counter being un-reliable - various bits in the top byte appear to change as the bottom byte crosses the 0x00 / 0xFF boundary. This soun...
17 years agoI like the elegance and simplicity of your solution. It also explains why all of the (synchronous) test harnesses that I wrote for the part in Verilog all worked fine, yet the real-world failed.
On an unrelated subject, do you know if there are any global switches for the MAX7k to put the whole part into low(er) power, slower slew rate mode ? I am currently configuring every pin as non-turbo which is a bit tedious. Regards, Mark
