16 years agoMAX3000 CPLD bi-directional I/O with 5V pull-up
Hi How would I create a bi-directional pin with open-collector output on a MAX3000 CPLD? I have started the design with an open collector driver driving the pin and a 541 type buffer fo...
16 years agoI assume you're referring to MAX3000A devices? You're doing it correctly. Though I'm not sure what you mean by 541 type buffer on the input (I assume you're referring to a 74xx541 part). Info is found on pages 20 & 21 of the datasheet:
http://www.altera.com/literature/ds/m3000a.pdf Jake
