ken_51
2 years agoMAX10:UFM Parallel Read Timing Details
Device MAX10 10M02SCE144 Environment Windows 11/Quartus Prime Lite 17.0/ModelSim ALTERA STARTER EDITION 10.5b I am using Altera On-Chip Flash IP and want to read data from UFM in parallel, incremen...
ken_51
2 years agoThank you very much.
I already understood that the maximum clock is 7.25 MHz.
However, I did not expect that it would take more than 50 clocks to send back the readdatavalid pulse.
There seems to be no effective solution to this problem.
I am giving up on the 10M02 device and replacing it with a larger capacity device.
