10 years agoMAX10M25SC which pins needed for 64io use?
Hello all. I am new to FPGA, and will be using the basic elements of a current processor Veriloh that have been shared online. The goal is to create a 64io device similar to the current processors...
10 years agoI can't advise as to whether it will work or not. The device can be used as a JTAG host via USB. So, it certainly looks to be the part. However, you will have to consider what drivers you are going to use to control your on-board JTAG host and programming of the FPGA. You won't be able to rely on any Altera software/drivers for that. It's designed to support a USB-Blaster and not a custom solution such as you're proposing.
Cheers, Alex
