10 years agoMAX10M25SC which pins needed for 64io use?
Hello all. I am new to FPGA, and will be using the basic elements of a current processor Veriloh that have been shared online. The goal is to create a 64io device similar to the current processors...
10 years agoAre you considering developing your own loader based on a FT2232H device? "I am new to FPGA" - try walking before you run. Use altera's usb-blaster (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf) for development. You can 'load' your MAX 10 using that. Depending on the MAX 10 kit you've ordered a programming solution (USB-Blaster on board) may come as part of the kit. Forgive me if I've misunderstood but I don't think developing your own programmer/loader is where you should be focusing your efforts.
Cheers, Alex
