9 years agoMAX10/DE10-Lite clock skew issue
As a simple demo, I wrote verilog code for an updown counter on the DE10-Lite board using buttons, LEDs and switches. KEY[1] is used as clock and KEY[0] is used as synchronous reset. The counte...
9 years agoYour code:
always @(Updown, Reset_n, Count)
begin
if (Reset_n == 0)
next_Count <= 0;
else if (Updown)
next_Count <= Count + 1; // if Updown, increment Count
else
next_Count <= Count - 1; // else decrement Count
end
always @(posedge Clock) // flip-flops
Count <= next_Count; // count on rising clock edge The problem is your fundamental design: * The first always block is completely unclocked asynchronous logic. * The second always block you have a one-rank synchronizer that synchronizes a multibit value (next_Count) to the clock. The first always block will end up generating a large blob of combinatorial logic involving the Reset_N, Count[], and UpDown signals. Both UpDown and Reset_N are not clock synchronous. Moving the design to be a fully synchronous counter, and adding input synchronization to the button push signal, should be much more tolerant of placement/routing timing variations: Revised code:reg UpDownSync1, UpDownSync2;
begin
UpDownSync1 <= UpDown;
UpDownSync2 <= UpDownSync1;
end
always @(posedge Clock or negedge Reset_n)
begin
if (Reset_n == 0)
Count <= 0;
else if (UpDownSync2)
else
end
