MAX10 single supply device - use 2.5V for VCC_ONE (and VCCIO, VCCA) ?
- 5 years ago
Hi Venelin,
Please refer MAX 10 FPGA datasheet https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf.
The Table 6, Power Supplies Recommended Operating Conditions for Intel MAX 10 Single Supply Devices, recommends minimum voltage for VCC_ONE upto 2.85/3.135 V. Referring this, 2.5V is not recommended for VCC_ONE.
There are example power supply guidelines also available. Refer Pin Connection Guideline for Max 10 FPGA, https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf.
See Example 4—Intel MAX 10 (Single Supply) FPGA, which might suit your needs.
In addition you may refer the recommendation for JTAG provided in the following Knowledge database.
Hope this helps.
Ashlesha
Please let us know whether the previous solution was helpful for you.
