MAX10 RSU with C series ?
Hi XYu,
MAX 10 compact device type only support single configuration image with self-configuration capability. Thus in the Quartus project design only allow you to choose either the Single Compressed Image or Single Uncompressed Image mode. The compact feature does not support the Dual configuration image features thus you won't be able to use the Dual Configuration IP (for RSU function) your project design. If you require to use the Dual Configuration IP (for RSU function), you can only use with flash or analog type MAX 10 device.
You can refer this information from the following links:
a) Under Table 3. Feature Options for Intel MAX 10 Devices
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf
b) Under chapter 2.1.2.1. Internal Configuration Modes
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Nooraini
