MAX10 Read Dual Boot IP core values in simulation
I do not see any register or setting that disables the watchdog timer. Table 34 on page 62 gives no option to disable the watchdog timer and those are the only signals I have access to.
I connected the Dual Boot IP core using platform designer and saw a sample of the read and write waveforms and I recreated exactly the timing for reads and writes but I still cannot read anything. Trying to match the example waveforms makes it worse. See attached pictures for the example, my writes and my reads
Another update, I now
1. write 1 to bit 0 of offset 2 and wait for this to happen (I think, there is no confirmation)
2. Read bit 0 of offset 3 and wait until this reads 0 (happens after ~150 clock cycles)
3. Read from offset 4. This now reads 0h0001FFFF. This is definitely better because I am pretty sure I am actually reading something, but bits [16:13] of this register are 1111 which does not correspond to an msm_cs value.
I am suspicious of the initial write since a previous forum post (https://community.intel.com/t5/Intel-FPGA-University-Program/MAX-10-FPGA-Remote-System-Upgrade-RSU/td-p/655190?profile.language=en) had this problem and it was fixed by writing to offset 2. I have tried waiting for over 531 clock cycles for this write to take place and have tried moving on right away like the avalon timing diagram mentioned above. Am I doing the writes wrong? Can this IP core even be simulated?
