10 years agoMAX10 programming times and UFM persistence
Hello, I am working with the new MAX10 device and I have some questions: 1. According to the documentation, the internal flash can be programmed via a .pof file; this works but takes a long time...
10 years ago --- Quote Start --- Just to close it: 1. USB Blaster II really makes it go down from 3 minutes to less than 30 seconds! 2. By using the cdf file generated with the quartus programmer GUI, I can use the command line; and by unchecking all check marks and then only the CFM program one, the UFM is not erased (only the middle line must ge checked). --- Quote End --- Great job Fernando! Glad you managed to solve your problem :)
