10 years agoMAX10 programming times and UFM persistence
Hello, I am working with the new MAX10 device and I have some questions: 1. According to the documentation, the internal flash can be programmed via a .pof file; this works but takes a long time...
10 years ago --- Quote Start --- Hi vinhael, 1. Thank you for the information. I am waiting for my USB Blaster II! 2. I tried that, but it did not work. I forgot to mention that I am currently working with Quartus 14.1; I didn't try it with 15.1 yet. I have an extra issue: I need to be able to do that via command line (currently using "quartus_pgm -mJTAG -opv;max10_config.pof") for our production line and I didn't see how. BR Fernando --- Quote End --- Just to close it: 1. USB Blaster II really makes it go down from 3 minutes to less than 30 seconds! 2. By using the cdf file generated with the quartus programmer GUI, I can use the command line; and by unchecking all check marks and then only the CFM program one, the UFM is not erased (only the middle line must ge checked).
