10 years agoMAX10 programming times and UFM persistence
Hello, I am working with the new MAX10 device and I have some questions: 1. According to the documentation, the internal flash can be programmed via a .pof file; this works but takes a long time...
10 years ago --- Quote Start --- Hi jordanf, 1. What did you use to program the MAX 10? If you are using USB Blaster, then you can consider USB Blaster II for faster programming time. 2. If I am not mistaken, in Quartus programmer; you have the option to tick/untick CFM and UFM. To configure just the CFM, make sure you tick just CFM(leave UFM unticked). I believe this will just configure the CFM, leaving your UFM intact =D --- Quote End --- Hi vinhael, 1. Thank you for the information. I am waiting for my USB Blaster II! 2. I tried that, but it did not work. I forgot to mention that I am currently working with Quartus 14.1; I didn't try it with 15.1 yet. I have an extra issue: I need to be able to do that via command line (currently using "quartus_pgm -mJTAG -opv;max10_config.pof") for our production line and I didn't see how. BR Fernando
