10 years agoMAX10 programming times and UFM persistence
Hello, I am working with the new MAX10 device and I have some questions: 1. According to the documentation, the internal flash can be programmed via a .pof file; this works but takes a long time...
10 years ago --- Quote Start --- Hello, I am working with the new MAX10 device and I have some questions: 1. According to the documentation, the internal flash can be programmed via a .pof file; this works but takes a long time (about 3 minutes); -> is it possible to have faster programming times for the MAX10 configuration? 2. When I program the MAX10 flash, the UFM is erased; we keep important data in the UFM and when we update the configuration we would like to keep the previously stored information in UFM; -> is it possible to program the MAX10 configuration without erasing the ufm? Thank you for your help. --- Quote End --- Hi jordanf, 1. What did you use to program the MAX 10? If you are using USB Blaster, then you can consider USB Blaster II for faster programming time. 2. If I am not mistaken, in Quartus programmer; you have the option to tick/untick CFM and UFM. To configure just the CFM, make sure you tick just CFM(leave UFM unticked). I believe this will just configure the CFM, leaving your UFM intact =D
