11 years agoMAX10 Internal Configuration Error
Hi everybody, I'm actually working with the new MAX 10M02SCE144C8GES and I have problem with the internal configuration which doesn't work. The FPGA works good when I program it with the .sof ...
11 years agoI would suggest to monitor the nconfig, nstatus and conf_done signal status. All these need signals need to ne high to ensure the configuration is successful. Make sure the to use the correct pull up resistor value as recommend in the MAX10 handbook.
