11 years agoMAX10 Internal Configuration Error
Hi everybody, I'm actually working with the new MAX 10M02SCE144C8GES and I have problem with the internal configuration which doesn't work. The FPGA works good when I program it with the .sof ...
11 years ago --- Quote Start --- Hi Danish, Yes I'm using a custom board. And I haven't tried .JIC file, I'm only using the quartus programmer. --- Quote End --- I have just checked the datasheet of MAX10, it actually has a built-in configuration memory and doesn't support JIC :) I think this might be an issue of POR delay in your case, try using standard POR instead of FAST in convert programming file (if not doing already) and also check configuration mode.
