11 years agoMax10: Error with Single Uncrompressed Image
With the Max10 Dev board I would like to use the configuration mode "single uncompressed image". 1) Setting up the QSYS with "single uncompressed image" -> Generate HDL 2) Quartus -> Device ...
11 years agoI can't explain that, no. Assuming you have a working solution I'm not inclined to spend more time going through it in detail to try and explain it. It could easily be a bug/oversight in Quartus that prevents you from creating a single image without initialization - there are sometimes subtle oversights like this. Given the App Note specifically states the flash doesn't need initializing, I'm a little surprised.
Cheers, Alex
