11 years agoMax10: Error with Single Uncrompressed Image
With the Max10 Dev board I would like to use the configuration mode "single uncompressed image". 1) Setting up the QSYS with "single uncompressed image" -> Generate HDL 2) Quartus -> Device ...
11 years agoIn the Qsys system there is:
- onchip_flash => initialize memory content NOT checked => Configuration Mode set to Single uncompressed image - onchip_memory2_0 => initialize memory content NOT checked Refering to AN-730 option 2, the initialize memory content should be set to unchecked. Do you know why it does not work in this case? Thanks!
