fogl
6 years agoMax10 DDR input/output
Hello everybody, I am looking for the possibility to interface a Gbit ethernet IC with four input and four output DDR lines. I am reading the Max10 documentation and i was not able to figure out if ...
fogl
6 years agoThank you for your suggestion. I was able to test a simple example of DDR input/output using the IP wizard. I connect the clock to PLL which was set to source synchronous mode.
Klemen
