11 years agoMAX10 can't accept 125 MHz clock without timing violations
Hi. I'm using quartus 15.0.0 64-bit on Windows 7 pro. I'm working on a design that uses an MAX10 (10M08SAU169C8). The design calls for two clock domains. The first is 50 MHz and the second is...
11 years agoThe error message in this case is a bit of a red herring. The issue is you haven't defined the clock output of the PLL. You can do this by adding this command to your SDC file:
derive_pll_clocks That will trace the input clock and create the necessary generated clock commands. Tim MN FAE
