11 years agoMAX10 ADC(BeMicro Max10) output value
Hi Guys, I am testing Max10 ADC function. When I put or assign 2.5V to AIN channel, I can't read only 4005, it should be 4095. It seems to be incorrect or truncate data. When I put or assig...
10 years agoHello
I have the same problem with the ADC. Could you please tell me where I can find this VCCIO1A and VCCIO1B node on the board so I can fix this problem. is it possible to locate it on the actual board? (upload a photo maybe) I don want to change the DC converter output setting because it may lead to other problems in other peripherals is there any way to work around this offset in software design I mean in the HDL code for the FPGA? thanks alot
