8 years agoMax10: ADC not working with .pof file
Hi I'm currently working with Max10M16DAF256 and I have a problem with the ADC. When using .sof file it works fine. When using .pof file the ADC does not work anymore, i.e ADC data is always ze...
8 years agoHi Alex
Thanks for fast response. I also found the same problem with Max10 ADC in another thread, but like you said there is no solution for this. The board is our self design board. The problem is that many of our boards are working fine with ".pof"-file, and some of them have this ADC problem. For the boards with ADC problem, we investigated in the hardware of these boards but unfortunately we didn't find any problem with the hardware. Like mentioned above, the boards are working with ".sof" and even ".pof"-file when the supply voltage is always on. After the supply voltage is reset, the ADC does no more work while the rest is still working correctly. Thanks Bien
