8 years agoMAX10 ADC Control Core - command_ready never high
Is there any reason why the MAX 10 ADC control core command_ready output is always low and never goes high even though I'm not giving it any sample to convert? This is from the MAX 10 ADC User ...
8 years agoHello,
1. I've checked using signal tap by observing the data going through the nodes; it shows zeroes. 2. I am using a custom board with the MAX10 chip 3. I have tried code that works on the dev board but when flashing the same code on the custom board, nothing shows up. --- Quote Start --- Hi, 1.How you have checked (elaborate steps you followed and about the design)? 2.Are you using development board or custom board? 3.Have tried with example code? https://cloud.altera.com/devstore/platform/?acds_version=16.0&family=max-10 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End ---
