RichJ
6 years agoMax10 10M04 on-chip-flash erase failure
I have written a FPGA updater to write to CFM0 using a state machine and the On-Chip Flash Intel FPGA IP. This works well for the the 10M02SC part. However we have moved to the 10M04SA part and...
JohnT_Altera
6 years agoHi,
I am not sure why it is showing error. The other reason of the timing take longer is that you are using Serial Interface where it might be taking longer time. You could try to use Parallel Interface setting in your On Chip Flash IP.
