Max10 10M04 on-chip-flash erase failure
The 10M02 and 10M04 is having different architecture. May I know if the simulation loaded is the same?
Have you tested it on hardware?
I have generated the IP component along with its simulation model for both the 10M02 and the 10M04SA using platform designer. The test bench requires a slight modification to instance the correct flash model, and to reduce the address bus width connected to the flash component for the 10M02SC. The correct flash unlock and flash erase control register values, along with the appropriate CFM0 address ranges need to be uncommented in the device_pkg.vhdl file.
I have attached zip files of the IP I have generated in platform designer (int_flash_ctl_10M02.zip & int_flash_ctl_10M04.zip). I believe the configuration is defined by the generic map values of the onchip_flash_0 instance in the file int_flash_ctl_10M04\int_flash_ctl_10M04\simulation\int_flash_ctl_10M04.vhd, and the equivalent file in the 10M02 IP.
I have also checked the protection bits read back from the status register. They are correct to allow read and write access to the CFM0 sector. Sector 3 for the 10M02 part and Sector 4 for the 10M04 part.
I have tested the appropriate code on both the 10M02 and 10M04 hardware with the same result. On the 10M02 device I can erase and reprogram the CFM0 flash, but on the 10M04 it fails to erase the CFM0 flash.
