8 years agoMAX10 - Spikes at output pins upon startup
Upon starting up the 10M02SCU169 I see a spike at pins assigned as outputs that trying to drive low after configuration. I measured the pins of 1.8V and 3.3V bank and still see a spike on any pin ass...
8 years agoNot sure if your voltage measurements are reliable, but seeing outputs pulled high by a weak pullup during power-on is normal operation of all Altera FPGA. Outputs required to keep low level during power-on must be equipped with a strong pull-down resistor, e.g. 500 ohms to 1k.
Better use active low signaling for critical signals.
