8 years agoMAX10 - Spikes at output pins upon startup
Upon starting up the 10M02SCU169 I see a spike at pins assigned as outputs that trying to drive low after configuration. I measured the pins of 1.8V and 3.3V bank and still see a spike on any pin ass...
8 years agoHi,
You need to check the ground, It may be one of the issues. 1. Is measuring instruments (oscilloscope) connected to common ground while measuring. 2. Are you using development Kit? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
