9 years agoMAX10 - SignalTap makes project not working
Hi I have a custom board with MAX10 10M25SAE144I7G. When I try to add a lot of nodes (std_logic, and std_logic_vectors) and memory is almost full after compilation the project stops working. Signa...
9 years agoDo you set timing constraints on the clk?
Check the maximum freq of the clock of the design.
