11 years agoMAX10 - Remote reconfiguration
Hi all, We have a system which must be updated remotely by a CPU. I'm able to reprogram the CFM through SPI by the mean of the MAX10 On-chip Flash IP and a SPI to Avalon-MM bridge (I creat...
8 years agoDid you find any application notes that helped with understanding the required process for interfacing to and controlling the Avalon SPI IP to the internal FLASH Controller IP, also I'm not sure I understand the Dual Configuration IP usage. What hardware lines are required to be controlled directly by the host processor for reconfiguring and selecting which config to use? Sorry for what may be stupid questions, I am just getting started and have never used the Qsys utility or Avalon or Nios. I really don't want or need to use Nios (as used in the Altera App note)... just want to control everything through a SPI interface from a processor on a different board.
