10 years agoMax10 - high speed IO, low speed IO and something between
Hi All,
I am going to use 10M50SCE144 chip in my design and I am wondering about the difference between different types of IOs. According to the datasheet, there are two types of IOs - high speed IOs and low speed IOs. The datasheet has different tables describing the difference between those two types in different differential standards, but I am going to use the IOs as single ended 3.3V IOs and I need to achieve 133MHz speed on few of those pins. The question is, is it possible to use low speed IOs with 133MHz clock or I must use high speed IOs? Another question, the pin out table has few pins that are neither high nor low speed - the IO performance column is just empty for for pins (for example, pin 50 and pin 62). What is so special about those pins? Thanks, Alexey.No RepliesBe the first to reply
