10 years agoMax V CPLD Pull up for pins
Hi, I am working on MAX V 5M2210ZF324C5 device for my current project. I require some of the pins to be pulled up as this wasnt taken care in schematics. Is this possible for the present de...
10 years agoYes. MAX V has programmable pull-ups. Enable/disable it under the 'Weak Pull-Up Resistor' column in the Pin Planner.
Note: --- Quote Start --- The programmable pull-up resistor is active during power-up, ISP, and if the device is unprogrammed. --- Quote End --- Cheers, Alex
