16 years agoMax II Config Complete Detection
I currently have an issue where I am trying to separate a power-on reset from a "software reset". Basically, in our system we have a DSP that accesses several registers in a MAX II CPLD via SPI. The ...
16 years agoTo reset all registers to a defined state, you don't need a reset controller however. Simply assigne initial states to the signals. They are converted to power on set/resets. You should consider however two points:
MAXII (as well as many newer FPGA families) has only asynchronous reset, not set. - This means, the compiler inverts the register polarity internally to achieve an asynchronous set. - You can't use both, asynchronous set and reset for a register In some cases, you may want to assure the reset to be synchronously released. Then you need a kind of reset controller. Without an external reset input, I mostly use a reset counter, that should even resist an uncleanly starting clock. In VHDL, it looks like below:signal start : INTEGER range 0 to 7 := 0;
IF rising_edge(clk) THEN
IF start < 7 THEN
start <= start + 1;
reset <= '1';
ELSE
Reset <= '0';
END IF;
