17 years agoMAX 2 with STRATIX 4
we are migrating from stratix 2 to stratix 4, on stratix 2 we were using EPM570(MAX 2) with a spansion flash. on the altera reference design they have used EPM2210(MAX2) with a similar size fla...
17 years agoSome reference designs also use the MAX II for other functions beyond the configuration needs.
Check out the entire reference design (one-wire perhaps) and you may see that swithces, LED, etc are also routed to the MAX II. You do not need that I suspect. As long as you have enough to do the addressing and data and control, you should be good to go.
