17 years agoMax 2 IC occasionally gets destroyed
In my hardware environment, a "Max 2" IC occasionally gets destroyed - it pulls down the 3.3 V power supply. What can be the cause for this? Can it be anything else than electrostatic discharge? The ...
17 years ago --- Quote Start --- check ALL pins between the pdf and your schematics & layout --- Quote End --- VCCINT and VCCIO are connected to 3.3 V; GNDINT and GNDIO are connected to 0 V; TDI, TCK, TMS and TDO are connected to pull-down resistors and to the Altera Byte Blaster; GCLK and DEV_OE and DEV_CLRn pins are used as "User I/O". --- Quote Start --- also use Quartus -> Assignments -> Pin Planer and check all entries. --- Quote End --- All "User I/O" outputs pins have a high impedance load; all "User I/O" input pins have an input between 0 V and 3.3 V. All unused "User I/O" pins have either an input between 0 V and 3.3 V or are unconnected. --- Quote Start --- check your project settings for this device how it should handle unused pins. --- Quote End --- They are reserved "as input tri-stated". On the conditions above, can any cause of the device destruction be excluded except the following? --- Quote Start --- ESD problems in your enviroment [...] voltage over and undershots on input pins, gnd bouncing --- Quote End ---
