8 years agoMAX 10: using two ALTPLL
Is it possible using two ALTPLL from one clock source with 10M08D? I tried instantiating two PLLs. One has 5 clocks, and the other one has one clock. But I got an error message during synthesizi...
8 years agoHi,
You can generate max of 5 clocks from one PLL. Not more than 5 clocks. Example in Figure 2-18 can be implemented for the 5 clocks. Maybe you can design a logic for 1 clock out of 6 clocks(4 phase-shift clocks plus 2 more control clocks) check which one can be implemented easily. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
