MAX 10 single supply LVDS max data rate
- 4 years ago
The Quartus does not consider the electrical and switching characteristics. For an IO the limit is put up by the IO standard, structure of the IO and the technology used.
Please consider the datasheet value as max data rate.
The timing report showed the highest achievable frequency of the internal logic and not the physical limitation of the IO pin. On hardware, the frequency will be limited by the numbers mentioned in the datasheet.
Hi, Ash_R_Intel.
Thank you very much for your answer.
Well, if so, then it's strange, I suppose, because we need to check in this case for all external interfaces whether our timings exceed the values in the datasheet . I always thought that TQ uses timing data also for the I/O buffer. So what in this case limits the speed?
Ivan
