IDeyn
Contributor
4 years agoMAX 10 single supply LVDS max data rate
Hi all!
I work with Intel MAX 10 FPGA, single supply (10M16SAU169I7G) The aim is to implement ADC interface using LVDS - desired speed up to 400 Mbps.
I created test project with soft-LVDS an...
- 4 years ago
The Quartus does not consider the electrical and switching characteristics. For an IO the limit is put up by the IO standard, structure of the IO and the technology used.
Please consider the datasheet value as max data rate.
Ash_R_Altera
4 years agoHi,
Does inspection result mean timing report number after running place and route in Quartus?
The numbers in datasheet are related to hardware characteristics of a high-speed LVDS pin.
Regards.
- IDeyn4 years ago
Contributor
Hi, Ash_R_Intel.Yes, it is timing report result after P&R in Quartus TQ.
Ivan
