10 years agoMAX 10 project ---- fpga reset
I have a tutorial for the SLS SD/emmc card open core so far i have populated all the pins but one... it is called fpga_reset_n but also reffered to in the top level verilog file as being pll_reset...
10 years agook thanks ! you guys have been so helpful so far, i really appreciate the good work you guys put into the tutorial i am reading. i will email you guys if i have any more problems. by the way the board i am using the BEMICROMAX 10 from arrow, has no extra ground pins, will any old ground do ? I am having to power the sd card from a seperate battery pack and regulator.
