MAX 10 Projamming Issue 10M25SCE144I7G
Hi INITDONE,
Have you tested it (the .jam file) on another Max 10 device? What's the behavior?
Try to make a new simple design, generate it into a .jam file, and try to configure it.
fakhrul
Hi Fakhrul,
Thanks for the Reply.
We have only one Max10 device is there and made very simple design with 11 IO pins , just loop test only.
Tried with SOF and POF and JAM file but all file are showing same error and error is below,
Error(16353): Expected the Max 10 device at index 1 to be of type analog, but detected device of type compact instead. Ensure that you are using the correct programming file.
configuration scheme is Internal Configuration
Configuration mode : Single compressed Image (3200Kbits UFM)
still not able to resolve the Issue. Please help us
Thanks & Regards,
Ramesh S
